View: 821|Reply: 1
5600H Wifi speeds are trash and wired is worse
[Copy link]
1
Threads
1
Posts
39
Credits
Newbie
Rank: 1
Credits
39
Post time 2023-05-01 13:20:25 | Show all posts |Read mode
Edited by Jazmac at 2023-05-01 23:11
I updated the network speed on my cable to 1 gig download speed.  A speedtest on my IPhone 13 Pro Max on wifi gets a download speed of 870 but speed test on the 5600H maxes out at 340 pretty consistently. I've flushdns and the speed doesn't change.  What's worse, when I connect using a wired connection, the speed drops significantly. 250 download speeds.
5600H Windows 11
Any help with this?
Reply
Use magic Report
5
Threads
2317
Posts
7160
Credits
Super Moderator
Rank: 8Rank: 8
Credits
7160
Post time 2023-05-02 22:41:29 | Show all posts
Sorry for the trouble. Don't worry, the PC has one-year warranty.
Could you please send us a picture of SN on the bottom of the PC and a picture of purchase record ? Let's do some troubleshooting. Here are some potential solutions:
1.Please make sure your wifi signal is full.
2. Make sure that the distance between the PC and the router is less than 6 meters.
3. Please uninstall the wifi driver and then resatart the PC to see if it works.
4. Please right click the windows ---setting -troubleshooting ---other toubleshooters--- internet---run , let the PC diagnose the problem and solve it automatically.
5.Please update the driver. Here is the driver https://mega.nz/file/fvQWUDwa#EV ... KWcrV72J52XzM4APp8c
Here is the tutorial https://mega.nz/file/mvAS1bQK#xX ... LDUFcxN5WUi6OrYy2js
6. Go to device manager , click the property of the Intel wifi driver, ---advanced--choose property 802 ac, value also choose 802 ax.
Reply Support Not support
Use magic Report
You have to log in before you can reply Login | Sign up
Points Rules
Quick Reply To Top Return to the list
